отмена
Отображаются результаты для
Вместо этого искать
Вы имели в виду:
Battery problems help
Tonizpt1221
Посетитель
I typed the following code 73784....   and tested battery appeared following message
Actual batt ( uah ) 2419000
Bad please replace it !
Xperia z5 xperia z5 e6603
should I change the battery?
Теги (1)
3 ОТВЕТ 3
Jonas
Мастер
Hi @Tonizpt1221,
Do you experience any unexpected behaviour with the battery in your device? This will always be more trustworthy than what a service menu tells you.
If you don't, I don't see any reason for you to replace the battery now and it's better if you wait until you see a big decrease in battery performance or if you start to experience sudden shutdowns and that the device can't be powered on without connecting it to a charger.
Let me know if that helps! Slightly_smiling_Face
Tonizpt1221
Посетитель
Jonas
Мастер
Hi @Tonizpt1221, sorry for the late reply.
In this case, I agree with you! Slightly_smiling_Face
