i still got the idea that when you take out the battery and connect it again, this issue is gone
but we cant open the phone without making damage...
suddenly when I used usb wall charger my phone start charging then disconnect directly and it keep repeating like that until I remove it from usb port
I did a factory reset but nothing changed
Is there any solution for this problem
i have same problem too .. i downgrade to kitkat 4.4.2 and this problem solved .. Lollipop have many issues
yes
how do you downgrade when you're phone not connecting correctly to pc ? my phone do that even when I plug it to pc
@ararfeh198 To check if you can do this with your device switched off hold volume down and connect your device to your Pc and see if it's detected and installs a driver if needed
after connection my phone to laptop my phone stop charging directly but my laptop seems to install the drivers any way my phone problem is only with charging, I can transfer files between both devices
@Michy_Spiky I downgrade to kitkat but nothing happen my phone still doing the same when connecting to charger
@ararfeh198 Sorry to hear this but you would need to either return your device to the place of purchase or contact Xperia care and have your device inspected http://www.sonymobile.com/global-en/support/contact-us/
