mic don't work after I put monile in water
hosamalzagh
Hello I put my Mobil in water for 1 minte
After I remove it from water my mic note work
Tags (1)
1 ACCEPTED SOLUTION
Jake-SonyXperia
Champion
After 7 days, the water should have cleared, this could be a hardware issue in this case.
I suggest that you speak with Customer Care for further help. Use my signature to fine contact details for Sony Mobil within your region.
I do apologize for the inconvenience this may cause.
6 REPLIES 6
SophiaW
Enthusiast
Hi hosamalzagh
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
You should contact your local Sony Xperia Customer Care team - you can find contact details for your region in the link on my signature.
Jake-SonyXperia
Champion
Hi hosamalzagh,
You could also try making sure the mic section has no residual water, make sure to lightly blow it out or use a cotton bud to dry up any left over water that may be stuck in the grate.
Uliwooly
Was it fresh water, a pool, salt water?
hosamalzagh
The seventh day is still the microphone does not work knowing that put him in rice
hosamalzagh
fresh water
Jake-SonyXperia
Champion
