Hi, when you receive a call does it ring/vibrate etc as normal but stay black
If so could you try going into Settings - Apps & swipe to ALL then scroll down to InCallUI & enable.........:smileysmileywink:
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Do you experience the same behaviour if you boot the phone into safe mode?
/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008
If yes, I suggest that you take a look in the following thread to see if can be related to anything similar:
http://talk.sonymobile.com/t5/Xperia-Z3-Z3-Dual/Can-t-answer-incoming-calls-on-xperia-z3/m-p/918498
WHERE to find this INCALLIU ??????
Settings-apps-all,scroll down to InCallUI.
HELLO: Please help me with this problem. I messed it up somewhere. I used to see an incoming call bar. Slide it to the right will let me answer. NOW I don't see that bar anymore. WHEN I have an incoming call, I tap on the PHONE icon and nothing happened. I had to set it up it with SMART ANSWERING to answer any incoming call. How Do I get back this AMSWERING BAR ? I like this original feature better. THANKS
Hi, go to SETTINGS........now scroll down & click on APPS........now you will see the word DOWNLOADED in small writing at the top.....press & swipe this till it moves along past RUNNING then it comes to ALL..........scroll down to InCallUI
Hello: THANK yOU> i COULD GET TO APPS- ALL AND SCROLLED DOWN BUT COULD NOT FIND CALLUI. I just wonder why.
Here is my problem. I messed around with setting auto answering and recorded my own message but I did set it back to OFF. I seemed clicked on a tern called CALLUI..but could not find it anywhere to reset it back... MY problem now is this: When I have an incoming call, I do not see that ringing bar and slide it to the right to answer. NO bar for me to pick and I clicked on the phone handle icon, I could NOT answer the call either. I managed to ansswer incoming call by setting the phone to SMART ANSWER feature. How can I restore the Incoming call BAR ????
Will click on CALLUI once disable it ?? IS this the source of my problem ???? I am frustrated. HOPE can get HELP....
So when your phone rings the screen is NOT BLACK.......you see the details of the caller but you cant physically answer
I remember I clicked on CALLUI from somewhere but don't remember how to find this CALLUI to set it back. It was definitely not from APPS-ALL.
IF I can find CALLUI, I may be able to solve my problem.....
