Hello I have problem with my Sony z2 I have weak mobile signal after update to new android 5.1.1 build number 23.4.A.1.264
Before updates signal was better.
You can't unless you use flashtool or xperiafirm or contact your Local support
If I was you, I would repair the phone with PCC
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
If you base it on the bars that's not the way to go, as they don't really represent the signal strength, that goes for all phones.
settings > about phone > status > signal strength, check here and also check with your carrier if there are any network connectivity issues.
when I put sim card in old Sony L I have signal. The same is when I put in iphone i have signal. When I put in Sony z2 the same sim is no service. Before update I had good signal I try put different sim still is the same. How can I install old version android, when I bought phone I had android 4.4
Bridge (for Mac)
After repair software signal is better. Thanks for help
