Problem with speakers when taking calls - Very Heavy Noise
Prashant_R
Hi. I have recently purchased a Sony Xperia Z ultra C6802. Since yesterday there is a problem that when I make a call, the sound from the other side sounds to be very heavy. I'm not sure if i am able to describe it correctly but its similar to the kind of voice you would hear from a walkman in the olden days when the batteries would go low. It is the same issue with and without speakerphone. (when I hold the phone to my ear)
However, the issue is related to phone calls only. When I play music or listen to Videos, it works perfectly fine.
Kindly advise.
Tags (2)
1 ACCEPTED SOLUTION
profile.country.RO.title
_alexdon_
Settings-call settings-untick microphone noise suppression.
alexdon
5 REPLIES 5
_alexdon_
alexdon
Prashant_R
Seems to work,   There is also an option below it called "Slow Talk" which slows down the voice of the other party.  I found it while looking at the option you suggested.   Just that I'll need to verify again tomorrow.  Its 12 midnight at my pace and cant make a call to anyone at this time Slightly_smiling_Face
Thank you so much though
Tags (1)
_alexdon_
Ok,have a good night.I hope it works.
alexdon
Prashant_R
Hi Alexdon,
I verified today and the problem is resolved.  It was a simple solution but I proabably would never have been able to find it on my own.  Thanks much for your help.  Have a good Day.
_alexdon_
You are welcome.
alexdon
