Problems with the mobile network , no signal, the red cross
andru_bara
Help!!
1 ACCEPTED SOLUTION
Uliwooly
Are you using a MICRO SIM card or did you trimmed a regular SIM card?
The best thing to do is to contact your local Xperia Care as this could be hardware related, since you dropped it
http://support.sonymobile.com/global-en/contactUs/
8 REPLIES 8
Hampus
Champion
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
Have you tried to restart the phone? Or remove/insert the SIM-card to see if this can help? Otherwise, I suggest that you try another SIM-card to see if same behaviour appear.
andru_bara
yes I tried it , insert another SIM card and tried all the sim card in other phones, everything worked, I dropped the phone a few times, the SIM card phone recognizes , but the red cross indicating that no network
Uliwooly
Uliwooly
You can also repair the phone with PCC
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Tags (1)
andru_bara
no, nothing helped. has already done all that you advise
Jake-SonyXperia
Champion
Hi andru_bara,
I can only suggest that you contact Sony Mobile Customer Care, as the device may require servicing. Please use the link below.
I apologize for the inconvenience this may cause.
andru_bara
thank you
Jake-SonyXperia
Champion
Any time, glad I could help.
