Ruined my phone , need help fixing!
Ziad_
So it's been one of those days , my phone fell on the ground and the back got completely shattered but it was still working , but then I spilt some Pepsi on it so I decided to rinse it till it's clean , cause you know , it's waterproof and stuff but now not only is the back shattered , the screen started to flicker and then it wouldn't start anymore and all it does is constantly flash red lights in the corner of the phone when it's being charged.
I know i've probably screwed up badly but is there a possible fix?
Tags (1)
1 ACCEPTED SOLUTION
SophiaW
Enthusiast
Hi Ziad_
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
I advise contacting Sony Xperia Customer Care as soon as possible as your phone will need to be sent into a service centre.
2 REPLIES 2
SophiaW
Enthusiast
Hi Ziad_
Andy_324
Hi, so i smashed the back screen ages ago on my phone (August last year) was working fine up until the weekend just gone past. The screen started to freeze as i was goin on it after i unlocked it, then just go black, if you pushed the power button however the screen would light up but nothing would come up on the screen at all. Now ive discovered that if you press the lock button the phone makes a high pitched noise and goes off again when u lock the phone.
Is there any way to fix this.
