Walkman lock screen widget missing
ViperR
Hi, for the last couple of days I have seen that the Walkman widget that is present in the lock screen when I am listening to music is absent.
As you can see in the pic, the Walkman is running but the widget is absent.
16 REPLIES 16
Kerioke
Hi Senhoy, thanks for your response, I already had widgets enabled.
However since you guys mentioned removing Smart Key, I went into the Smart Key app and turned OFF the Music (default) and now the walkman widget and my calendar widget is now accessible on my lock screen!!! Thanks Guys.
profile.country.en_GB.title
zaim7890
Isn't there anyway to get this to work without removing smart key ?
profile.country.RO.title
_alexdon_
Disable music like the user above suggested.
alexdon
zaim7890
I was hoping I wouldn't need to do that.
_alexdon_
Other option would be removing smart key app.
alexdon
Bales
Good day, I have a similar problem I can't add any widgets on my lock screen and "settings> security" is not present as an option.  How do i fix this? I just upgraded to Android Version 5.0.2, Build number 14.5.A.0.242
Brucewayne_tdk
Hi.
I have the same problem on my Sony Xperia Z and I don't have smart key installed what should I do? I also went to security but I can't find the enable widget option
