Good evening. I'm posting this weird thread because I got an hardware fall on my SECOND Xperia Z3 Compact, for the SECOND time on the jack connector for headphones. This sound kind of apocalyptic to me, 'cause I use my phones for 70% as music player, and there's why I decided to go with Sony after 4 years of using my Galaxy S1 (thant never had hardware problems. NEVER. Jack connector perfectly working after 4 years of usage). Since I found beauftiful my Z3C's performance, interface, ALL - I'd really like to mantain my choose on Sony Xperia Z3 line (not the plus, not the furnace 810, please), so
my question is: will the jack connector in the Sony Xperia Z3 (NOT COMPACT) I'm going to buy stop working in 1 ~ 2 months of usage?
Sorry for the eventual "bad english" and hope to ear you soon.
Oh, and... nope. I'm not a troll. Just a person who don't like to waste money that easily.
Yes, they are: https://www.amazon.it/gp/product/B00HX9AJ5M/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
Are you trying to go Off-Topic? You know, this technique doesn't work with me.
Allice, no one is going off topic, you have few responses about the jack, what other informations do you need? Most of the new phones have the jack inserted, if they wont work its either the hardware or software or you were inserting them with a big amount of force. Saying you haven't inserted your headset with a big amount of force wont change anything because sony will say is it your fault or the jacks.
@Alis,
Please understand that we are here to help you and most of us are not with Sony, we are other Xperia owners assisting you and others with their problems. We enjoy and like our Xperia devices and want to help. So, understand that no one is using techniques or tactics to get you off-topic or steer you in the wrong direction.
You might want to consider getting another headphone set to see if they cause you any issues. The ones I am using are as follows:
I have several sets of these and they work without issue with my Xperia... given the phone controls don't work like they did on the Samsung Galaxy S3, but that is expected.
What information I need? Well: is the Z3's jack connector quality the same of the one on Z3 Compact?
If yes, bye bye Sony.
I not, Xperia Z3 all the life.
Is it a weird question? Surely less weird of you and insisting that I put my headshet in phone with a big amount of force when I wrote you two times that I don't. And when I talk about a serious thing (to spend 550 euros for a flagship) and people ignore what I'm saying / want to understand only what they want I get a lot irritated.
@Alis,
Those of us who have not owned both the Z3 and the Z3c can confirm the build quality or parts of the phone jack. We don't have the technical or build specifications of these devices.
With that being said, your experience will vary (Will be different.) than my experience or others. Thus, there are many of us that do not have your problem. Also, one or two devices, your Z3c, doesn't mean that all devices have that same issue, this assumes that you aren't causing the issue accidenlty or on purpose. It is possible that both of your Z3c devices came from the same location or build batch? There isn't a way for you to know this, but it is possible that the batch that your devices came from did have an issue. In any case, if you get it from a respectible source, you should be able to return it if you are not pleased with it.
To change headset... well, it may be a solution, unfortunately for the next Z3. It's so sad that the headset desined for this line of products cause al this issues to the jack connector. Saddest is the fact that this headset has a BIG sound quality and I have to change it 😕
Well so, thanks for help. I'm going to sleep now, hoping tomorrow someone will gove some other suggests to avoid this future problem.
Edit: No wait, if you read my first message I said that this is the second Xperia Z3C which loose the jack connector.
You don't have to convince us.
Either:
1. you got a Z3 with manufacturer defects.
or
2. you are causing this issue.
Either or, contact your local Xperia Care.
Uff. It's too hard to explain a so common defect like the Z3C's one. Look at this, I have exactely the same problem of the user who opened this thread: /t5/Xperia-Z3-Compact/Headphone-jack-loose/td-p/843137
What's the point on creating a new post on the same question/topic that has been answered?
This topic is locked,please do not create other threads.
