Xperia z Bluetooth problem
Arunlav
    i am using xperia z with SBH20  .initially they were build 4.2.2 jelly bean in xperia z. so no issues on that time . but i am facing the problems in bluetooth after upgrading from 4.2.2 to 4.3.Other thing is SBH20 bluetooth device is working fine for other devices.  pairing fine, working fine but the problem is some noises coming while am hearing the songs. that noise is really irritated. many times i done factory reset also. but no use. can anyone tell how can i rectitify
1 ACCEPTED SOLUTION
Sam
Legend
Legend
Is the noise happening only in certain areas or at certain times and what does the noise sound like?
Don't forget to mark posts that answers the topic as Accepted Solution.
If you find any post helpful, press Kudos.
What are your thoughts about this forum? Let us know by doing this short survey.
19 REPLIES 19
Sam
Legend
Legend
Arunlav
its coming all time. one thing is some old songs hearing properly but  AR Rahman song was coming with noise.
Arunlav
I forget to tell one thing.. normally i put into 3.5mm jack means the sound was very clear . only the problem is coming  in bluetooth.
Sam
Legend
Legend
That is odd, however if it happening particularly with certain tracks I would advise removing them from the phone and then re-adding them from the original source again.
Hasstef
Sam , I've discussed the issue with Johan from your team and he acknowledged the issue. I have noise with all music while streaming via bluetooth to Sennheiser MM550-x or Jawbone Big Jambox, and no problems with wired connection.
wizzy
Hi, don't know if I'm posting in the right area but I have a bluetooth problem with my Xperia z after upgrading to jelly bean 4.3, the screen mirroring function no longer works properly, it connects then disconnects instantly from my C 2G HDMI dangle, worked fine before the upgrade, any help would be appreciated
wind2k9
 Yeah...from the new 4.3 bluetooth and wireless are not working propertly..especialy when u open them both. The bluetooth devices sometimes disconects...For example my smartwatch 2 sometimes disconects and i think it afects the phone some how. i noticed that wehen i unlock the screen and try to send a message fast...the mesage could not be send..after 5-10 sec if i try again...it is working. Also if the bluetooth is open..and i open even wireless...the wireless icon dosent apear anympore and also it not conects to the network. So i think the last updates screwed something.
creancracker
I also have this problem with my Bluetooth car phone connection dropping every few seconds and then reconnecting, very annoying,I have tried connecting with different phone__works perfectly, problem only occurred after last upgrade.
essorst
I have the same issue, please some one can provide solution !
