Whenever there are multiple notification from same application in the notification tray and I try to expand it to see details, it expands and instantly shrinks back. Though this doesn't always happen (frequencey is 60% of the times this issue occurs), but it is really annoying. Please fix it.
We have found the cause for this and it will be fixed in the update to Android 6.0.
This may happen if you use PIN, pattern or password as screenlock.
@uliwooly Almost all apps, gmail, whatsapp, email etc. The same apps' notification expansion works fine at times and other times doesn't work.
Does your phone has a protective case or film?
do you experience the same while on >>> safe mode
Same problem here with z5 compact.
