You're welcome, not a problem.
That's normal, you had the screen on most of those 7 hours, I don't see any issues, remember games will drain your battery fast, you can see that
1. your carrier/network coverage its terrible, that drain your battery fast
2. you had WiFI on all the time, and your phone or some apps were downloading/uploading
3. you were playing minecraft
4. your screen was on for most of those 7 hours
I don't understand your question
Off-late I'm also facing this excact same issue
Refer to my thread /t5/Xperia-Z3-Compact/Z3-imp-queries/m-p/913852#M4988
Post your Power management screenshots here so we can compare.
https://play.google.com/store/apps/details?id=com.playfulgeeks.gservicefix&hl=en
This app on playstore resolved the issue for me , lots of people say it doesnt do anything and i thought it seemed wierd as why doesn it want you to turn on location services ?
i was scepticle but wanted to try before i investigated the services constantly in use listed in (developer optuions > Process Stats > menu > stats type > Background ) manually
bottom line this does do something, as after running it for the first time my phone actually went to sleep (check in battery stats 'awake time') ( i also didnt charge to 100% just ran it )
my phone was taken off charge at 05:50 today, by 11 am (when i performed the fix )it was at 75%, looking now at almost 16:00 im at 62% and i have used it quite a bit this afternoon too so its a definate improvement , i know its going to last so much longer now that it goes to sleep !
