Phone cuts call at 1:40min xperia 1.and other problems.
Erlend
Hi.
Im having a lot of trouble with my x1, almost all calls fails after 1:40 minutes, it Just gets quiet and when i look at the phone its Just back at the lock screen. Tried restarting and repair phone on xperia companion. Even reinstalled the phone. It has nothing to do with my carrier.
Im also having trouble with the fingerprintscanner, about 95% fails. I have registered my most used finger 6 times...
Also it will not for the love of god connect to Android auto, ive tried 10 different usb cables, and yes with sync.
4 REPLIES 4
RottenFoxBreath
Enthusiast
Has your car got an android android auto icon to select?
You really need to read the app description on the Play Store regarding it. Sure you can run a lite version just using the app, but to need to make sure your car supports it.  And try the cable that came with the phone.
As to your calls have you tried using speakerphone?
And don't register the same finger multiple times, it does nothing. Just make sure you follow the animation instructions and move your finger about like it shows you, so you make a full picture of your print
Erlend
It happens Even with speaker, over bluetooth and while holding the phone. For me it appears to be that the phone doesnt handle networkswitching, almost like it falls out when it changes from 4g+ to 4g. I know others with the same phone having the same problem.
AS to Android auto, im using the original cable on a 2018 vw caddy that supports it, i can see the app Just popping up and then Just closing itself, and then the car looses connection..
Bt audio and calling works Just fine..
I have tried everything with the fingerprints.. It Even fails sometimes when i register New prints.. So it has to be the sensor..
profile.country.PH.title
MarlonUk1
Does this happen when you are on safe mode ?
Erlend
Yes. All the problems are there, Even in safe mode
