120hz at 1080p
profile.country.GR.title
alexhill
120hz at 1080p
Hi, desperately need help here as this is driving me nuts.
I cant get 120hz at 1080p on my 65xe9005.
I have conected my pc with amd 590 which more than capable trough hdmi to my tv.
I have tried every possible setting including the enchanced option on tv, even creating a new resolution ar 1920 1080 120hz  but all i get is the tv wont do 120. This tv is 120hz capable and this is driving me crazy.
Please help
7 REPLIES 7
profile.country.IT.title
Marino.Manolo
120hz capable?... :confused:
Manolo
Marino.Manolo
Have you confused the Hz of the panel with those of the signal?
Manolo
alexhill
Thats crazy! All the reviews I read tested the tv as 120hz capable, also there are many se9005 owners on forums that are using it at 1080 120hz, and I am sure I was told it was 120hz from the shop I bought it from just a month ago.
Its also listed as 120 capable here
https://www.displayspecifications.com/en/model/65f6a4b
Could it be a europe vs usa specs?
So is this tv not capable of 120hz? It supposed to be sonys premium model..
IamNic
Hello @alexhill,
the TV has a refresh-rate of 120Hz (NTSC) or 100Hz (PAL), it just doesn't support 120Hz/100Hz signals.
It interpolates the frames in between when using e.g. a 60Hz or 50Hz signal.
Could you please link the reviews, which stated it would work with 120Hz/100Hz signals, since Sonys product page clearly states the highes refresh rate signal it supports is 60Hz.
- Nic
Marino.Manolo
120 Hz is NTSC Panel's Refresh rate (100 Hz in PAL).
Manolo
alexhill
Heres the first one that pops up Ill find the others too
Tested 1080p @ 120 Hz
https://www.rtings.com/tv/reviews/sony/x900e
alexhill
And here is another
"The 65-inch TV boasts 4K resolution and HDR support, a panel with true 120Hz refresh rate "
https://www.tomsguide.com/us/sony-xbr-65x900e-4k-tv,review-4952.html
