Although it has worked previously the 3D function on my Sony KD-55X8509C no longer works. Using either the Action Menu or Settings:display the option to turn 3D on no longer functions, it is set to "off" and cannot be changed, 3D content cannot be played either from a USB or from 3D content on Youtube although both have worked previously. Is the issue linked to the recent software update or is there a fault with my TV?
Hi there
I have just tested the 3D on my KDL-43W805C tv using a clip from YouTube (see pics below). The 3D option is in the Action menu and can be turned on. I can only suggest a factory reset. If that fails, can you provide more information. Such as which youtube clip? If its a 4K 3D demo, then this will not work.
Thanks for your reply. Yes I have tried a factory reset but still no 3D. The 3D clips from Youtube that used to play fine no longer do. Then 3D food fight did work very effectively in 3D previously:
Thanks
Im going to report the issue to Sony, as you arnt the only one. Another thread is :
https://community.sony.co.uk/t5/televisions/unable-to-turn-on-3d-mode/td-p/211612
I have a feeling the issue is isolated to 4K model/s
Thanks. I've also been in touch with Sony Support, they were unable to solve the problem via a telephone diagnostics test and a factory reset. The issue has been "escalated"by Sony and I am now waiting for an engineer call out/repair.
Hi there
Thanks for the update. I can confirm that this is on Sony's 'Todo' list.
Hi there
This is a classic case of the lack of communications between departments 😞
Latest text from DBS local Sony TV engineers, dated 8 March: "We are currently waiting technical information regarding your Sony KD-55X8509C 3D problem"
