I have my tv connected to Denon reciever AVR-2000 with optical cable. I have tried to make sounds from tv to come out thru reciever with no luck.
Oh. It appears that tvs system sounds (menu cliks) comes thru only tv speakers and not from reciever? Turned netflix on and watched some show and it works just fine.
Have you verified?:
Settings > Sound > Speakers
Select which speakers to output the sound.
Inside this category: TV Speakers, Audio system
Settings > Sound > Digital audio out
You need to configure the [Digital audio out] settings according to your audio system (Availability of [Digital audio out] depends on the region/country.) Inside this category:
- Auto (Select this if the device connected via DIGITAL AUDIO OUT (OPTICAL) is compatible with Dolby Digital)
- PCM (if the device is not compatible with Dolby Digital).
Manolo
