Bravia Won't Turn On Unless Unplugged/Replugge
profile.country.IE.title
josh2019
hi,
recently my KD -43xf8796 has intrtmittingly stopped turning on using the green power button on the remote. Have to unplg at power wall socket to turn TV on. Firmware version is PKG6.6545
Can anyone suggest how to fix this?
8 REPLIES 8
Sean_Mc
Moderator
Hi Josh,
Please see the following article here that should help you resolve the issue or define a cause.
Let me know how you get on.
Best wishes,
Sean
josh2019
hi,
The issue occurred again this morning. there was no response from the tv even pressing the power button on the right hand side. had to unplug from ac power.
khallergard
For me this problem was caused by the RF usb receiver for my RF mouse. Solved by replacing with a bluetooth mouse.
josh2019
I have a usb receiver for a mini keyboard connected. I will disconnect it to see if this fixes.
josh2019
Unfortunately the third morning of trying to turn tv on there was no response. Had to unplug from ac power once again. any further suggestions appreciated.
profile.country.BG.title
rumenangelov
I have same problem with Sony Bravia KD55-AF8.
this start after last update ...
any ideas?
TimH3at5
I am experiencing this same problem is there a fix?
rumenangelov
Unplug any SD-cards, flash drives or HHD and try.
