Connecting active sub to KD49X8309C
Mormad
Hi,just purchase a KD49X8309C and well pleased with it,I currently have. REL active sub and wish to connect it up tv.When researching tv it said it specs that it has a subwoofer output and all I can find is the 3 connection points on the left hand side for sat/TV aerial connections are but the top one has SUB against it but instruction manual only shows this as a tv/sat aerial connection.Am I right in saying that the reference to a sub output is the phono jack point for sony's wireless sub system or can someone advise me differently.
Thanks
1 ACCEPTED SOLUTION
Not applicable
Hi there
The only sub you can connect to the TV is Sonys SWF-BR100.  See HERE for more info.
2 REPLIES 2
Not applicable
Hi there
Mormad
Thanks very much for info I guessed that,have managed to run sub for now until £'s spare for next purchase from headphone port not the best but improves sound quality from weak tv speakers.Once again thanks for help.
Darren
