KD-49XF8096 WiFi Issue
slipd83
Hi guys,
Recently started to get "WiFi not Connected" message pop up in the top right corner of the screen?
Using the latest v6.7165 firmware.
Any ideas? Nothing has changed on the router (Now TV - UK), and all my other devices are rock solid. The message doesn't actually appear to mean I loose connectivity?
Thanks.
Tags (2)
1 ACCEPTED SOLUTION
slipd83
I'm not sure which variable cracked it but disabling ip6 on my router and assigning the TV a static ip, appears to have fixed it! No more "No WiFi" notifications.
6 REPLIES 6
profile.country.IT.title
Marino.Manolo
Check the time on the TV.
slipd83
Thanks for the reply!
I checked and its set to "Program time" - have toggled it to Network time? See if that makes a difference...
slipd83
Nope, that didn't fix it unfortunately... any other ideas?
Thanks!
Marino.Manolo
Give the TV a Static IP, from the Router.
Divide networks if you have 2.4 and 5 GHz together.
slipd83
I've assigned the TV a static ip and turned off ip6 - going to see how that goes overnight.
Thanks!
slipd83
