Use Sony TV remote to control Sky Q 2TB box
RankFTW
HI everyone. I have just recently bought a new Sony TV KD55XG8796BU and am having trouble getting the remote to control my Sky Q 2TB box. I have done the initial set up where it asks me to provide the manufacturer of the cable box and have tried both Sky UK and BSkyB. It is really frustrating as I'm coming from a Samsung smart TV and the universal remote for that worked perfectly and I don't fancy having to use 2 remotes. I have also tried to manually enter the model and make of the Sky Q box but it did not find any matches. Does anybody have any suggestions or fixes please.
13 REPLIES 13
colmcasserly
Anyone able to get this to work? It shows Sky Q as a Bravia Sync device under the enabled list. But doesn't seem to work when on the Sky platform. The TV is an A80J
Is there another (older) way to do this using 4 digit codes codes? I know you can program the Sky remote to work with TV but what about the other way around. Prefer to use the Sony remote for all. #
Wolfie59
I’ve managed to get my Sky Q remote to control the Bravia XR volume. But I can’t get the Bravia remote to show me the Sky Q programme guide when I use the ‘programme guide’ button on the Bravia remote. Any ideas, please?  I’ve used the Bravia ‘set-up set top box’ setting but it still doesn’t enable the programme guide button to work.
sylsyl
I know I can use the SkyQ remote, and do most of the time, but can't understand why I can't set up the TV remote to control Sky. UEI/Quickset make the Sky remote after all, and that's the data base that Sony use!
I can go to:
settings
channels and inputs
external inputs
tv box setup
set up by model number
follow the instructions and select "sky" then I get a whole list of options.
No matter which I chose, including Sky, Sky Q or Sky UK, I can't get it to accept my model number 32B12C (even just searching starting 32, which is all the models I think, I can't get it to find any).
How do I get it to work?
LightFoot
Specialist
I can go to:
settings
channels and inputs
external inputs
tv box setup
Hi @sylsyl   Reaching into the back of my brain, have you tried SkyQ (no spaces) as the model number. All Sky Q models (32C, 32D, 32B0, 32B1 or 32B2) use the same remote and codes.
