Just Bought a C5 Xperia and got update 5.1 lolipop, 2 days ago bought MBH20 to go with my C5, Using it its on phone calls is fine, but when I use it on Whatsup voice call it stop working, BBM voice call, Line same problem, I do not know it is the Bluetooth incompebility or something, I tried on my friends Sony Z3, it just works fine with voice call on whats up.
Did repairing the Software, but no help, I do not know whats wrong with it, anybody has the same problem? or any setting should I know about?
BR
Topic edited by Rickard
are those 3rd party apps updated to the latest versions? also try to delete app data settings> apps> all apps> clear data.
also try to re connect /re -pair your bluetooth to the accesory./
whatsapp, line, bbm are not Sony apps. For what you described is that those apps have not been customized to work on the C5, a way to test this, try to make a voice call or video call on hangouts if it doesn't work then
boot on > > > safe mode try to make a voice/video call with hangouts, if it works then it could be that either a third party app its causing this
Try this, connect your Bluetooth device, go in settings, Bluetooth and verify settings: You should enable both telephony and media.
Check if it works.
Did that way before, if the phone is incopitable than its fine by me. I can sell the phone and get a new one, but I will be sick if I am the only one has the problem, especialy in Indonesia service center is bad, service can g up to months, why I ask in this forum because I want to know is it only my phone has problem. And of course I like the phone but it seems has problem everytime than I am afraid to buy the same brand.
Hello,
So I just connected my stereo-non-sony bluetooth headset to the C5 ultra and tried a Whatsapp call with it and it worked.
Long story short, it could be a Lollipop 5.0/5.1 (not 5.1.1) issue/limit with setting and this make all the bluetooth devices NOT REALLY compatible with all protocols. You said it that you tried it with a Z3 and it worked, was it with Lollipop 5.1.1? I bet yes.
... or it could be that your headset is not fully compatible with the profiles available in the C5. You should try other bluetooth headsets to see if it works or not but I am almost sure that an update to Lollipop 5.1.1 (it's not going to happen) and to Android 6.0 will fix the incompatibility issue.
Probebly that the Android isue then, I will try on other bluetooth a non sony one? but that would be funny right bought the same brand so that it is compitable...but then again...:smileysilly::smileyangry:
I will try to find my friend a non sony bluetooth. see what happens,
thanks i will update.
BR
