music automatically stops
Nrjs1997
Whenever I connect the headset I got with the phone, after sometime the music stops and after few seconds it gets start also. At first I thought that it was a problem of the new update of Walkman app so I uninstalled the update. But the problem still persists. How can I solve this problem.
1 ACCEPTED SOLUTION
Uliwooly
@Nrjs1997
Remove the SD card > uninstall any antivirus, taskillers, ram apps, booster apps > settings > apps > all > music > clear data > restart the phone > report back
8 REPLIES 8
Uliwooly
@Nrjs1997
Where are you storing the music? internal storage or SD card?
Nrjs1997
I use to store it in SD card.
Uliwooly
@Nrjs1997
Nrjs1997
Thanks..it worked...can you tell me the cause of this problem.
Uliwooly
@Nrjs1997
You could test your SD card again (w/o the antivirus, taskillers, etc), if you experience the same issue, then its an SD card problem, perhaps the SD card class it's too low (2, 4, 6)
AjayK
Xperia C3- The music palyer has some problem from th first day.. The songs suddenly stop for 2 minutes and restart again...I have even got it fixed and restored fromt the sony centre... I am really fed up about it... Can you give some permanent solution Have tried with safe mode and unistalling Antivirus and ram booster still same prblm ...
Ravit
I tried the steps provided above, it didn work.. still the problem exists
could u pls help me on the issue
Anandselvam
Having xact same prob, no use of this, tried everything, even got service from Sony centre, still having the same prob...
