I have a DSC-W170, recently I have noticed there is a black hole of about 5mm dia, appearing on screen and photos.
I have cleaned the lense, but still the same problem.
Any idea as to how this can be fixed?
thanks
Hi Alex, welcome to the Sony Forums
If this was a removable-lens camera, I'd say it was probably dust on the sensor. It's not impossible with a fixed lens, just less likely.
It would be much easier to ascertain if you could upload a sample image which shows the problem clearly. Just click the camera icon when replying and hit 'choose file'.
Mick
Thanks Mick.
Thanks.
Interesting... as I thought, it's not on the sensor. When you can see detail 'underneath' the mark it's almost always something on the lens.
You say you've cleaned it and the thing causing the mark is likely to be big enough to see, so it must be something inside, perhaps on the rear element.
I'm really not sure how easy this will be to remove, but you might be able to get some idea by taking it to a high-street camera store and asking if their tech can look at it.
Sorry that's not much help! Hope you get somewhere with it.
Mick
Thanks.
