Imaging Edge App
Nigelar99
Imaging Edge App
I have recently paid a lot of money for a Sony RX10 M4 camera. The camera is fine. But I continue to experience problems using the atrocious Imaging Edge Software to transfer photos from the camera to my Pixel6a phone running Android 14. The camera appears in the connected  cameras panel (I have successfully scanned the QR code). 99% of the time the camera does not connect. It has connected 4 times so the connection sometimes works. I send bug reports as requested although whether anyone is reviewing these I doubt. There is no means of contacting the developers via the email address on the playstore appstore. Any emails are bounced. Support appears non existent. The playstore review section seems to consist of hundreds of disgruntled users.
I want to know what Sony are doing to address this issue having shelled out ££££££s to you. I expected better.
15 REPLIES 15
MaggieGreene
@Nigelar99 Yes, the Creator's cloud app is also accessible from smartphones or tablets, you can learn more about the app and how to use it here: https://helpguide.sony.net/di-app/ccw/v1/en/index.html
BigDave
I think I must be missing something. When I try to connect with my RX10 iv, it states my camera is not compatible with the Creators App, only with IEM:
[image0.jpeg]
Is there some sort of workaround that I’m not aware of?
Dave
Nigelar99
Agreed. According to the App FAQ, only the following cameras are listed as supported. It says for everything else use the useless IEM
Supported Cameras
FX3*, FX30*, α1 II, α1*, α9 III, α7R V*, α7S III*, α7 IV*, α7CR, α7C II, α6700, ZV-E1, ZV-E10 II, ZV-1 II, ZV-1F, ILX-LR1
For info, I've had a little more success using the NFC file transfer function compared to wi fi.
BigDave
Thanks for confirming my fears!
Unfortunately, Apple iPads do not have NFC capabilities.
Regards
Dave
MaggieGreene
@Bigdave Alternatively, you can transfer the images to your PC or Laptop using the card reader then send it to your phone.
BigDave
Thanks for this. Unfortunately, my main use of WiFi transfer is when I’m away from home, hence transferring to iPad and not a PC. This is particularly useful when I’m on holiday, being able to transfer on a daily basis, often hundreds of photographs.
