Freeview Play
wagolynn
Freeview Play
I see Sony are now on the, 'Freeview Play', list of supporting manufacturers.
I assume this is software, if so can it be loaded onto a Sony KDL32WD756BU TV?
1 ACCEPTED SOLUTION
Owen_G
Hi Wagolynn,
Welcome to the Community. To access Freeview Play, you either need a TV with Freeview Play built-in, or a separate Freeview Play recorder, which you can link to your current TV.
Unfortunately your TV does not have Freeview Play built-in, so you would therefore need a separate Freeview Play recorder.
We hope this helps.
Owen
3 REPLIES 3
Owen_G
Hi Wagolynn,
We hope this helps.
Owen
wagolynn
Many thanks for reply, Owen.
