Unit will not boot or expel Blu Ray disc
Audible clicking of tray mechanism
How do I reset ?
keith
Hello @SLOWRAMBLER,
disconnect the power cord, hold down the eject button on the device then reconnect the power.
You may need a second person to help you.
- Nic
Hello @SLOWRAMBLER,
- Nic
Thanks for taking the trouble to reply Nic
You were correct I had to look under the hood and use a screwdriver
None of the Sony remedies worked
Fixed it myself with help
