- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
Doubletaps during text writing #Xperia L3
Hi, i have problem with writing texts or messages . When im writing some text, sometimes it doubletaps that gives me for example ,,hhelp,, . It is a little bit annoying. It looks like software problem because everything else works well. Do someone have idea how to fix it?
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I have same problem
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Samme problem here as you can see.
How tto repair it? Im using gboard but on swiftkey threre is the same probleem.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
@Rastamaniacand @Annanikol , do you have any screen protector mounted on the device that might interfere with the touchscreen? Also, have you been able to carry out a quick test of the touch screen to see if the hardware works as intended? Find and tap Settings > Support > Xperia Tests > Touchscreen.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I have done test and everythig seems good. I had screen glass but removed it because i thought it was problem but not. Mostly it happens whhen typping fast. Also multitouch keeps crashing while used in games. I think its screen's multitouch problem.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
I was about to do the same with gllass. Warranty did not help. Service has installed Android one more time with no effect. Sometimes even when i want to delete llast letter it types llast letter instead of delete. Can be the CPU of thiis phone too slow for typing ? I do not think so. In my opinion it is defect somewhere in CPU or in connection CPU with data. It is really annoying when I cannot write message as fast as I can.
- « Предыдущий
- 1
- 2
- Следующее »
