I tried to update my phone (Xperia X10) to 2.1 and everything was going fine but on the third step of the process it would not update my phone. i tried several times and still would not update it and kept failing. so i gave up trying. but when it came to turning my phone back on it would not let me and kept coming up with a white triangle with a yellow exclamation mark in the middle with a phone next to it. this also comes up when i attach it to the computer. how can i fix this please?
Try to run it with Update service
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/xperiax10
if that fails you can always relay on this other method (if you don't care about your warranty) this for sure will work.
first time trying it didnt work but tried again and my phone is ime. thank you sooooooooooooooo much :smileygrin:
I'm glad it worked, I was going to tell you, if you use the XDA way and you need to use your warranty you can always flash the original firmware back to your phone
