LukeHli
KDL-42W655A MKV
I apologize in advance for my bad English. I have a problem with my TV, my TV does not want to play any MKV files, we can solve it somehow? Thank you in advance for your answer.
1 ACCEPTED SOLUTION
Not applicable
Hi there
First thing to do it to run the problem file/s using a program called Media Info : HERE
Compare the codecs used in the summary report, to the supported codecs list : HERE
If they do not match up, you will need to re-encode the file/s using a supported codec.  A suggested program is Handbrake : HERE
Hope that helps
1 REPLY 1
Not applicable
Hi there
Hope that helps
