naiqbal34
Motionflow Kdl55w805a
Hi all
 I have turned motionflow off on the TV, when watching movies I still see the soap opera effect. I am very disappointed after paying nearly £1000 for the TV that I can not enjoy watching
movies. Is there a problem with my TV that when I switch off motionflow it does not display movies as it should do. I need your support urgently,
Thanking all in advance
Najeeb
1 ACCEPTED SOLUTION
Not applicable
Hi there
Turning off MottionFlow should prevent any type of motion interpolation and therefore no of Soap Opera Effect.  If you set MotionFlow to Cinema, it should reproduce the same frame rate of the movie (ie 24fps) - Could try that?  Combined with Scene Select and Picture Mode as Cinema/Cinema 1
If you have experimented with the settings and are still not happy, I would suggest contacting Sony Support : HERE
4 REPLIES 4
Not applicable
Hi there
Try setting:
Scene = Cinema
Picture Mode = Cinema 1
And see how that goes. Personally I like MotionFlow = Clear :slight_smile:
naiqbal34
Thank you for your reply.
I have tried all different settings,
Scene select cinema, picture mode, cinema, tried all motionflow settings but picture still appears as soap opera effect, is there any way to remove soap opera effect on this model.
Thanking all in advance.
Not applicable
Hi there
naiqbal34
As suggested I have sent Sony support an email.
Many thanks
