'AV1 Sat' appears top let corner of picture when on Sky - how do I get rid off?
Try pressing the i+ button. When pressed this should cycle through input info, time and off in that order. Or so I have been told :smileygrin:
I posted something similar - it was driving me insane. i found a cure!!!! (for me at least).
On Sky remote - press "TV", then "i" repeatedly to cycle through the display info's
HTH
Perfect - Thank you
Thank you - The Information Button top left of remote control turns off this info as you said 'It is very very annoying' .
After a couple of hours of going through all the menus on TV/Skybox/DVD
, a 10 minute search on this forum provides the answer, thanks
