I'd appreciate if Someone could please help me!
I recently bought a VAIO VGN-FE41Z. I've been trying to create a recovery disc (as I'm supposed to do in case of problems). I click START, ALL PROGRAMS, VAIO Recovery Tool, and VAIO Recovery Utility. The User Account Control window appears. I click Continue. I select Create Recovery Media Kit and OK
and then I get "Cannot find the CD or DVD recorder. The recorder may be in use. Check your recorder then restart the VAIO Recovery Utility."
Needless to say, my CD/DVD is not in use. I've tested the drive and I can read a CD, no problem (I haven't tried a DVD yet 'cause I'm not sure which "DVD zone" I want to use).
I've also downloaded and installed the latest drivers. I still get the same message.
It's getting a little frustrating, especially since I've eventually come to the advice that I should run my recovery disc. I'd be very happy to do so IF I could create one.
Can someone please help?
Thanks in advance.
Scribbler
... sorry, one more thing, if I click Computer, Yes, I can see the DVD/RW Drive E:. That's also not a problem. But why do I continue to get this "Cannot find the CD or DVD recorder. The recorder may be in use. Check your recorder then restart the VAIO Recovery Utility." message?
Thanks!
Scribbler
Hi Scribbler59,
I have no idea whether a system recovery will solve your problem, but this should be, in my opinion, the first action on receiving a new machine.
You can achieve this without the recovery disks by tapping F10 at boot (when you see the Sony logo) and follow the on-screen instructions. This will access the hidden hard drive recovery partition and restore your machine to “as delivered”.
Be aware that you will lose add data on the C drive as this will be formatted as part of the process….
Hi Rich,
Thanks very much for the information on doing a system recovery. If all else fails I shall give this a try and see if it makes a difference.
I would, however, prefer to first try to find a solution to the fact that under certain circumstances my CD/DVD cannot be found.
Cheers,
Scribbler
Wow, I don't believe this. Spanking new VAIO laptop and I can't even perform the first most important step. I submitted a case to Sony e-support and I can't even get them to acknowledge receipt of my case submission, much less respond to it.
Thanks in advance.
Scribbler
You write:
I have a VGN-A217M with a Sony DW-D56A drive and PFS1. I can read everything okay - but I can't write to DVD.
Question 1 - Is PFS2 likely to help?
Question 2 - If I download PFS2 from the above site - how do I instal it?
Any help appreciated.
Thanks
Thanks Thalamus,
I'll give that a try tomorrow (it's after their service hours today).
Hi Scribbler59,
You may get a quicker response if you telephone Vaio-Link ..
I'm having some problems with the CD/DVD-RW drive in my Vaio FS315M. For some reason, it is able to write CDs and DVD+RWs, but when it comes to DVD-Rs, it cannot write them any more. When it was a little bit newer, it did write CD-R/RWs, DVD+Rs, DVD-Rs, DVD+RWs and DVD-RWs, also DoubleLayer.
Could the lens be dirty or something?
Do you know where I can get a replacement that is compatible with the model that I have?
Thanks for all the help.
Thanks Thalamus,
