IF YOU HAVE DVD/CD DRIVE PROBLEMS - READ THIS>
Blencogo
:wink:
403 REPLIES 403
Thalamus.
Champion
Thanks...I´m going to try that...
Good luck.. :four_leaf_clover:
lee1973
Hello sorry if this request as already been noted via some other user,but i have had my VGN-AR31S for 3weeks, bought blue ray dvd's on playback i get stuttering play,and lose of sound,also the lip movement and sound are out of sync with each other? I have updated the driver via the self repair, but with no luck?
Any suggestions please, thanks in advance
Lee
Blencogo
Hi Lee and welcome to Club Vaio.
There is an updated version of InterVideo WinDVD BD for VAIO Version 8.0.8.123 available for download from Sony Vaio Support AR31S. This is meant to fix this problem.
There is also an updated Video driver on the same page.
:wink:
lee1973
:wink:
Hello B, :slight_smile:
Thanks for the warm welcome, i have tried all that you suggested, but it appears now that it will not play blue ray discs at all,plus i'm still getting stuttery playback on normal dvd?
Any other suggestions? :thinking:
Thanks again
Lee
darkside1990
My mashita something (???) drive was working perfectly this morning but has disappeared completely, it still opens and closes, the cd appears to be loading as normal and the orange light on the drive flashes, but nothing shows up in my computer, device manager, vaio hardware diagnostics, nothing. Help!!
Blencogo
Hi darkside1990 and welcome.
Have a look in Device Manager.
Expand DVD/CD-ROM Drives - is there a yellow warning?
If yes, then double-click on the Matshita drive and tell us the Error Code - it will probably be 37, 39 or 41.
If it is, we can fix it!
:thinking:
MattWilson
Its the upper and lower filters that are descibe above. Had the exact same problem. Some software installation usually causes the problem. I think its code 39. Here is the link for what to do.
darkside1990
Thanks for the help, however there is no DVD\CD-rom drives tab to expand under device manager! the world is out to get me!
sks
Hello
If anyone is having a problem with the DVD/CD drive on this LAPTOP ..
please dont try to fix it. I tried , i crashed my computer,i lost data had all kinds of nightmares. if you google this laptop you will see there are Clubs trying to sort the problem out !
I recently got in touch with a IT firm in Dubai, they sent me a new one for under a hundred pounds sterling .I fitted it and everything works now.
the dealer's e-mail is
sunil@ddcae.ae
just get a new one
good luck to all those still strugling
regards
sharad somaia :laughing:
taniasiak
I have a VGN-FE21B.My DVD-ROM is the SONY DVD RW DW-D520A.
My dvd-rom only writes SONY DVD-disks (+R) but this was not a problem
(I buy only SONY-ones...). It reads the disks I burn BUT DOESN'T READ DISKS
BURNED IN OTHER MACHINES(also SONY +R disks). It just tell me they are blank.
Did the re-install,couldn't find new drivers.Nothing...
Anybody have a hint why and hoe I can fix-it?
