My mic can only pick up load noises, e.g. if i flick the mic or shout loud etc...
I can't talk into it, because it doesn't pick up any sound volume.
Please help me!
Message was edited by: asevans42
The above should fix the problem if my guess is right and the microphone amplifier is disabled.
Good luck.
Thanks, but i uped it to 20dB and i still get the same result.. No sound.
Where do i check if my amplifier is disabled?
Thanks for the help!
Enabling the +20db option is the amplification I meant.
You may have adjusted the recording volume within a software which then passed on that setting to windows.
I'd check the volume mixer's recording settings.
