Hey Mouneer,
Are you talking about the hand gestures, or something else? Anyway, they should work like in the manual here.
https://helpguide.sony.net/mdr/wh1000xm4/v1/en/contents/TP0002752781.html?search=fast%20forward
Cheers.
there are two :
Fast-forward: Swipe forward and hold. (It takes a while until fast-forwarding starts.) Release at the desired playback point
Fast-reverse: Swipe backward and hold. (It takes a while until fast-reversing starts.) Release at the desired playback point
both doesn't work. I did the same way but nothing.
Are you using the application? ''Headphones Connect''
Also, I recommend resetting the headphones maybe it's a glitch, then try again:
https://helpguide.sony.net/mdr/wh1000xm4/v1/en/contents/TP0002752743.html
