hi @Kamelnageh
can you try to go to service menu? dial *#*#service#*#* ( the number equivalent on the dialer) and go to service settings >network type 4G only
can it detect 4g signals?
@nolramlb - I tried to connect using LTE only and it does but with AT&T (has a strong LTE signal), not with T-Mobile! (Has a LOW LTE signal, that's why I believe there is something going on related with thresholds...)
@Kamelnageh - Glad you found a solution and that now it's working for you.
