The accelerometer of my x performance stops after some days so auto-rotate and other stuff does not work anymore until I reboot...
@ianchen1967 wrote:
Below solution works so far after five days's trial. No functions and apps need to be disabled.
You should remember your google account and password before going.
(1) go to Settings - Apps - App Google, press Disable, this will unstall App Google from your phone, and no need to install factory version.
(2) go to Settings - Account & sync, press Google and click right-top corner to open menu, press Remove account.
(3) Restart your phone.
(4) Enter Google play store, you will be requested to login your Google account. Do it.
(5) Search App Google in Google play and install up-to-date version of this App, then open/enable App Google. Done.
Guys,
I am going to test the telephone after the "ianchen 1967's procedure" above reported.
Will let you know if it is working on my Xperia as well.
UPDATE: THIS SOLUTION IS NOT WORKING ON MY XPERIA
