Hangs while scrolling in dial log
X12
Thanks anyways.
 I got a small issue with my Xperia x (ds) device and on my dialed list my is phone is getting freeze when I swipe up down. Pl help
6 REPLIES 6
LiomSV
I have the similar issue on Xperia X F5122. The scrolling of recent call list is very twiching and works with delay, especially it is noticeable when I try to scroll a lot.
(In contrast to contacts list, which works smoothly and perfectly).
Model: F5122
Android: 7.0
Build: 34.2.A.2.69
Uliwooly
@X12 @LiomSV
could you test your device in >>> safe mode also if you could screenrecord this issue > upload it to youtube > post the link here
LiomSV
The lag is reproduced in safe mode too.
About video: imho, uploading the list of your contacts is not safely.
CameronT
Champion
Hi @LiomSV,
I am sorry to hear about this issue. If you are experiencing the same problem in safe mode then I recommend you perform a software repair using Xperia Companion
LiomSV
The issue is reproduced on other devices too. I think, it should be optimized and fixed by developers instead of repairing my single phone (and erasing all my data).
CameronT
Champion
@LiomSV
You can back up your phone before running the software repair, so you don't have to lose all your data. It is up to you if you wish to do this or not, however in my experience it resolves this particular issue most of the time.
