My Xperia X F5122 Isn't Detected by my PC and Laptop
hahaaOtaku
My problem is my phone isn't detected by pc and laptops.
So, I try all of the solution which was given by Sony,
1. Restart my phone, (more than 10 times).
2. Update my phone, (problem started, after i update my phone).
3. Reset my phone, (more than 4 times).
4. Try different cable.
but the problem still occured.
This will be my last solution, is there a way to solve this? or any other solutions?
1 ACCEPTED SOLUTION
hahaaOtaku
when i plugged in my device, my pc and xperia companion didn't detect my device. But in device manager it's there bu with an error
anyway i found the solution
  • Go to Control Panel -> System -> Device Manager.
  • Device Manager will display the non working device
  • right click on that device
  • choose Update Driver Software
  • choose Browse my computer fro driver software
  • Enter "c:\windows\winsxs" in the edit field named "search for driver software in this location".
  • Driver Update will search c:\windows\winsxs for the drivers there, this will take a while.
  • Good news. This will also fix this issue for subsequent driver installations - at least on my computer.
Good luck.
10 REPLIES 10
CameronT
Champion
Hi @hahaaOtaku, welcome to the community.
Can you please try enabling USB debugging, and see if it will notice it then?
To enable USB debugging please go to Settings > About Phone, then tap on "build number" multiple times until it says "You are now a developer". Then, go back to settings and there will be a new option called "Developer options". In here, turn on USB debugging.
hahaaOtaku
I've tried it, but it still not working
YoGem
Leader
@hahaaOtaku quick question.. What happen exactly when you plug the phone to your computer?
hahaaOtaku
Good luck.
hahaaOtaku
anyway, thanks for your help guys, CameronT and YoGem
YoGem
Leader
@hahaaOtaku that was exactly what I was going to propose next, just so you know.. it's not a problem with the Xperia software but a bug of Windows occurred after the last software update. You are not the only one having that same issue.
Norbi80
Thank you!!!!! 😊
CameronT
Champion
I am glad you got it sorted @hahaaOtaku, thank you for letting us know the solution Slightly_smiling_Face
Also, thank you @YoGem, I didn't know that. I have had a lot of people querying this.
Warrenhb
Good Day,
I have tried following the steps provided but my wondows 8 PC does not pick my phone up at all, i have tried using differnet computers(differnt operating systems) and all of my USB ports. The only thing that happens when I plug my usb cable from my Xperia X into the PC is it charges it, I have selected USB debugging mode in developer options but still nothing.
There is no option to select MTP..ETC ehn plugging in my phone. I recentley updated my system software to 34.2.A.2.47.
PLEASE HELP
