Nougat upgrade lowered cpuclock??!
doriandiaconu
I'm willing to buy the X Compact in a couple of days, but I saw something interesting online. Can someone look into this? A Sony representative especially.
"So I upgraded my X compact to official Nougat 7.0 a couple of days back and on first impressions I noticed some lag here and there mostly when scrolling
And I knew that Snapdragon 650 is almost clos to SD810 so what could be the problem because it was awesomely fluid and smooth on MM 6.0.1, so I started to dig up and here's what I noticed:
In CPUz app on MM it shows Qualcomm SD 650 @ 1.8 GHz but today I looked it up and in Nougat it shows Qualcomm SD 650 @ 1.4 GHz!!! And if you look at cpu cores, those 2 last core Cpu4 and cpu5 are stopped (i guess those two are A72@1.8GHz cores right?)
So conclusion is that A72 cores which are the main core to maintain smoothness are offline for some reason so Im asking developers to dig this up and help us out
Thank you"
38 REPLIES 38
profile.country.IT.title
Michelasso
Contributor
All cores are active. "busybox mpstat" shows activity for all of them:
F5321:/data/local/tmp $ ./busybox mpstat -P ALL
Linux 3.10.84-perf-g3245575 (localhost)	12/29/16	_aarch64_	(6 CPU)
09:04:28     CPU    %usr   %nice    %sys %iowait    %irq   %soft  %steal  %guest   %idle
09:04:28     all   15.69    1.39    7.31    0.39    0.00    0.32    0.00    0.00   74.90
09:04:28       0   17.66    1.51   11.69    0.70    0.00    0.53    0.00    0.00   67.91
09:04:28       1   19.56    1.67    7.43    0.43    0.00    0.24    0.00    0.00   70.67
09:04:28       2   13.61    1.26    5.14    0.28    0.00    0.31    0.00    0.00   79.39
09:04:28       3    8.94    1.08    4.06    0.27    0.00    0.16    0.00    0.00   85.48
09:04:28       4   27.12    1.36   12.36    0.02    0.00    0.12    0.00    0.00   59.02
09:04:28       5   24.53    1.56    9.27    0.01    0.00    0.93    0.00    0.00   63.69
So the bug must be in those monitoring apps in Nougat. The cores 4&5 are up and running!
adamlee2014
Contributor
Exactly the same on my Xperia XZ running nougat, restarting the phone makes all cores run again at maximum speed but as soon as you turn off the display it stops 2 cores permanently
SOUNI1
Same here look at CPU-Z after updating to Nougat...
Prince13
As usual, I'm already regretting updating after half a day...
Crazy_gump
As said two post berfore, this isn't true.
The A72 core are active but wrongly shown as stopped. No problem with bench or games except some which have problem with nougat in general.
SOUNI1
It's True when u restart your Phone all cores works but when u turn screen off 2 Cortex-A72 cores Will be off... I perform factory reset and nothing Change...
adamlee2014
Contributor
Same on my Xperia XZ!!!!!
Lord_viridis
There is nothing wrong with the phones, the problem lies with the poor implementation of nougat coding in their apps.
Download multi core monitor from Google play and you'll see the cores all working fine.
SOUNI1
Hmmm...  All cores working now Slightly_smiling_Face Screenshot_20161231-124054.png
