Hi @amsibsam2,
Welcome to the community
I can advise that you should have no issues with doing this as the device uses a function called Battery Care which helps with the charge of device and helps keep the battery function for longer.
There is no need to worry about leaving the device on charge at 100% as it will cause no harm to the device.
Note: always make sure to use the correct charger with your device.
I hope this helps.
Hi @amsibsam2,
I hope this helps.
No problem @amsibsam, yes you can continue using the device whilst it is on charge. If the device starts to drop in charge the device will simply start the charge cycle again.
I hope this helps.
