Usb debugging when batery already 100%
amsibsam2
Hi, wanna ask
Is it ok to let ur x compact connect to the usb while its already 100%?
Tags (3)
1 ACCEPTED SOLUTION
Jake-SonyXperia
Champion
Hi @amsibsam2,
Welcome to the community
I can advise that you should have no issues with doing this as the device uses a function called Battery Care which helps with the charge of device and helps keep the battery function for longer.
There is no need to worry about leaving the device on charge at 100% as it will cause no harm to the device.
Note: always make sure to use the correct charger with your device.
I hope this helps.
3 REPLIES 3
Jake-SonyXperia
Champion
Hi @amsibsam2,
I hope this helps.
amsibsam2
Oh nice, thanks for ur answer
And how if we keep using the x compact while its charging? Like browsing, youtube, messaging. Is is ok too?
Jake-SonyXperia
Champion
No problem @amsibsam, yes you can continue using the device whilst it is on charge. If the device starts to drop in charge the device will simply start the charge cycle again.
I hope this helps.
