Clear Blocked numbers
Sirnice
How do I clear the blocked numbers from my Sony Xperia
4 REPLIES 4
profile.country.PL.title
najodleglejszy
@Sirniceopen the phone app, then tap the three dots in the top right corner and go to Settings > Block numbers. you'll see the list of numbers you've blocked there. just tap the X icon next to the number you want to unblock.
Sirnice
I want to remove them from my phone.
najodleglejszy
@Sirnice  I'm not sure I understand. do you have contact numbers added that you've blocked and you want to delete them from your contacts? just copy the phone number, delete the contact, and then block the number in the same call blocking menu I mentioned in my previous comment.
Jonas
Master
Hi @Sirnice,
Could you please explain exactly what you want to do? Do you want to keep the numbers blocked, but you don't want the contact saved in your device?
There is no requirement that you need to have number you want to block as a contact in the device.
Please let us know exactly what you want to do and it will be easier for me and @najodleglejszy to assist you.
Thank you!
