Gps problem xperia xa2
Invitadopsico66
The last update released affects the performance of the GPS (eliminated the 3 options of saving battery, high pressure, only device) the gps is slow to locate the place more than normal and before that did not happen
Tags (1)
1 ACCEPTED SOLUTION
annoimush
You need to make sure that Google play store and google play services arent battery or data restricted. As well, make sure that Google location accuracy is switch on. This combination fixed it for me - now get gps location in 2 seconds instead of never.
3 REPLIES 3
annoimush
RogerG
I've tried your solution but it still doesn't work.
Rn10
Bonjour
Le GPS ne fonctionne pas. Ma position est introuvable.
Hello
GPS does not work. My location cannot be found.
gt
