Phone doesn't start after update
SantiagoC84
1 ACCEPTED SOLUTION
Emil
Enthusiast
Hi @SantiagoC84,
Welcome to the community.
I'm sorry to hear this. I recommend that you try and force restart your device. You can do so by pressing and holding the volume up and on/off keys for 10 seconds. Then try to start your device as normal, if it doesn't try charging your device for at least 30 minutes.
Also I'd recommend that you temporarily remove your SIM and SD card from your device to make sure they are not causing this behavior.
If you device still doesn't start I recommend that you perform a software repair using Xperia Companion.
Let me know how it goes!
4 REPLIES 4
Emil
Enthusiast
Hi @SantiagoC84,
SantiagoC84
Hello! Thanks for the support, i made it tonight and it's running perfect again 😊😊😊
Emil
Enthusiast
That's great to hear @SantiagoC84! :smileysmileythumbsup:
Let me know if there is anything else I can assist you with. Slightly_smiling_Face
SantiagoC84
Slightly_smiling_Face everthing its ok! TNKS!!! Slightly_smiling_Face
