I tryied to pair my phone via wifi to my PC but it says : Device already paired - The PC is already paired with your Xperia . To set up device again < remove the pairing. However i can find and unpair it( it doesnt show up on USB Connectivity.
On your phone open Settings then Bluetooth and you should see your paired devices - Long press the device in question and you should be given an option to unpair
The pairing is for file transfer via wife to my computer.However when I plug in the use cable and follow instructions it ends up saying that this device is already paired with the pc and if I want to repeat the pairing I first have to remove the current one.I am suspecting that it may belive it's the same device but when I used to have other firmware (talking about my pc).
I had the same issue and found the answer in this user's manual section:
I made un-pair and paired again (no more "Device already paired" message) but when selecting Connect on paired device Xperia trying to connect for some time and returns "Not connected" status without message what went wrong.
So I have another puzzle now
but hope it would work for you.
he said wife not bluethoot man cant see wifie paired device
