How to delete selected message of a sender from Xperia E device?
sonyc1504
Hi developer,
19 REPLIES 19
profile.country.RO.title
_alexdon_
Tap longer on the specific message,you will get some options. Delete is there.
alexdon
sonyc1504
Thanks...
I am explaining my situation now.
I have 150 messages from a same sender and its viewing as thread. Now some of 50 messages are important for me and i need to delete the other 100 messages. If i tap each and every conversation (100), it will take more then half an hour....
I am asking that,  Is it possible to select conversations and delete?
_alexdon_
You can delete a conversation but if you want to delete several messages from a conversation,you can only mark which ones you want to delete.
alexdon
sonyc1504
Thanks and i know very wel... Thats why I am asking, why the marking option not enable, while i tap messages or touching option key??
_alexdon_
Because it is available after you tap longer on a conversation or message. Don't understand exactly what you don't like about that.
alexdon
sonyc1504
Dear Developer,
Intially I got trouble to operate the mobile.. But now i am trouble to make you understand...
When i tap longer on a meassage, It shows,
1. Copy message text
2. Forward message
3. Copy message to sim card
4. Delete message
There is no marking options found.???
When i go for lower right corner options, It shows
1. Add recipient
2. Delete conversation
3. Edit recipients
_alexdon_
So you are running JB? In this case,what if you select delete conversations? Don't you get the marking circles? I do not have any Xperia with lower than KK to check here.
alexdon
sonyc1504
Sorry i can't get you?
_alexdon_
What firmware are you running on your device?
alexdon
