z3 Camera quick shot button not working
tolu
Hi. I´m trying to use quick shot button with my Z3. Bought 2 days ago. I can feel to different "clicks" and on the first click it focusec pic but with the second it does nothing. It doesn´t open camera software when it is turned of. I have quick laund enabled so that ain´t the problem. Starting to feel that have to go to repair shop with this
29 REPLIES 29
Uliwooly
You might want to take it to a Sony repair center
Uliwooly
You could repair your phone with PCC
PC Companion (PCC)
Bridge (for Mac)
Alternatives on How to backup Xperias
http://talk.sonymobile.com/thread/36355
Uliwooly
You can boot on safe mode
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
and check if it works or not, if it does then its an app acting up
tolu
tried to repair software and with safe mode on, but not working
Uliwooly
It could be a hardware issue, contact your local Xperia Care
http://www.sonymobile.com/global-en/support/contact-us/
ashishsingh007
There is 2 step press. It presses slightly then it focuses and press it even more an it will click the picture. I had same confusion which my friend solved after 3 months 😊😊😇😈😇😇😕😑😅☺😯😧😰
Uliwooly
@ashishsingh007 that's exactly what I try to tell him Face_with_stuck-out_Tongue
thieutos
I've exactly the same problem as Tolu. Tried everything and read all the comments above but nothing is working Slightly_frowning_Face
Uliwooly
Wolfang_raul
I'm having the same problem! Does anyone managed to correct this problem? I bought from ebay and I can't return it.
