Bluetooth won't stay connected to Macbook?
probedb
At the weekend I flattened my phone using PCC but still have an issue with Bluetooth.
I love the Smart Lock feature and at work I want to use my work Macbook Pro as a device.
The phone and Mac will pair without issues, but a few seconds after pairing the Mac shows my phone as not connected and the phone can't add the Mac as a device and there appears to be no options to force it to connect. It does the same every time I Forget the Mac and re-pair.
Any thoughts as to why it won't stay connected?
1 ACCEPTED SOLUTION
Rickard
Master
I don't have any 3:rd party tags to test with i'm afraid but Smart Lock is a part of Google Play Services so i suspect it will work with most tags. When using NFC, you will need to touch the tag every time you want to unlock though.
A bluetooth speaker on your desk could be an option as well but the phone will use that as sound output by default (you can disable call audio for it). But also bluetooth might have a long range. Up to 100m or so depending on the device and environment.
9 REPLIES 9
Rickard
Master
I'm afraid the Google Smart lock feature will not work with all bluetooth devices. It depends on what type of device it is.
When you pair the phone with another phone or a computer, there will normally not be any "idle" connection. Bluetooth will only connect when you want to use the connection for something (for example when you send a file or share the internet connection).
A bluetooth headset will however work as it uses the headset or handsfree profile where you keep the connection even when you're not in a call.
probedb
Hmm, seems a little odd that you can't pair it with a computer for this purpose as I assume all desktop/laptop Bluetooth implementations will behave like this?
Is there some action over Bluetooth I could use to force the connection long enough to use it?
Rickard
Master
Generally, yes. You need a software or app that creates and keeps a connection automatically but i'm afraid i don't know of any software that will do this for Mac. Trusted location could perhaps be an alternative if you want to keep the phone unlocked at work?
probedb
Many thanks Slightly_smiling_Face Too many people in the building and because it's accurate to maybe 80m, it's also next door to a bus station so don't want it unlocked around there Slightly_smiling_Face
My next thought was NFC. Can I just use the NFC tags you can buy from amazon etc or do I have to program them with something first?
Rickard
Master
probedb
Thanks for the help Rickard. I read about the NFC tags and trying to decide if it's actually quicker for me Slightly_smiling_Face
Rickard
Master
If you are interested in a wearable device a Android Wear device like SmartWatch 3 would work for bluetooth unlock. I also tested it with my SmartBand 2 and this also works. SmartBand 1 will however not work with this feature.
probedb
Excellent, many thanks Slightly_smiling_Face
TheTube
Go to System Preference
Then choose 'Sharing'
Unlock to make changes
Finally, tick the box with 'Bluetooth Sharing'
That should be you sorted. G'luck!
